Kenmore Elite 796.71423410: Drum Never Stops
reicherb
Michigan
I've got a Kenmore Elite 796.71423410: that will run through a cycle correctly but on occasion after the cycle stops and the controls shut off, the drum will continue to turn. Cycling it would cause it to correct. It's happening more frequently now. In fact, I had to unplug it to get it to turn off. As soon as I plug it back in, the drum turns while the controls are dark. Is this a stuck relay? Is it an easy fix?
Brad
reicherb
Michigan
I can't find it for less than $175... Are you 100% sure that's it based on my description?
Brad
Yes Brad, that's what It sounds like to me, but you can always have Sears come out to confirm it if you want.:)
