- 665.12793K310
- Sears Kenmore
- 6-10 years
Hello, I'm a newly registered member. I've found this site to be very helpful in troubleshooting my dishwasher issue but the fix still eludes me. My Kenmore Elite 665.12793K310 has the previously discussed not cleaning well and the diagnostics are giving me F9E4 and F10E3 error codes. The dishwasher will complete cycles but is just not cleaning well.
I first disconnected the vent motor connectors as Jake has advised, cleared the error codes but still got the F9E4 and F10E3 codes after running a wash cycle. I next replaced the diverter/LSA drive motor assembly, cleared the codes and ran a wash cycle, still got the same error codes afterward.
I ran a full diagnostic cycle and observed during Interval 10 minute #3 the Clean LED (actually Complete display on this model) came on indicating LSA motor status good but during Interval 10 minute #4 the Complete does not light, indicating a bad LSA sensor.
I also noted after completing the cycle the LSA does not end up at the "Home" position noted in the diagnostics sheet. Looking on line I found Whirlpool P/N W11126005, located one on Ebay and installed it. Same symptoms, F9E4, F10E3 and no Interval 10 minute #4 "good" status. I contacted the Ebay seller who stated the part I purchased W10380483 32600005 is not the same as the original W10380177 32600004 sensor in my machine.
Is this true, online info seems to indicate both P/Ns cross-reference to W11126005? What should my next step be? Is there a way to test the sensors to verify if they are good? Is there another possible problem at this point? Thanks in advance for any guidance.
