Kenmore Elite Dual Fuel 5 burner range down temperature control doesn't work
PDH
Pittsburgh
Oven works, however when we turn it on the minimum set temperature is 350 degrees and the down arrow button will not reduce the set point to a lower temperature. the up arrow button works fine. Any ideas?
PDH
Pittsburgh
Thanks Jake, I was afraid of that. I had to replace it a number of years ago for another reason [don't remember specifics] and it was hard to find then. Guess we'll live with it like we have for quite a while. Not buying another range until I absolutely have to.
PDH
Pittsburgh
Jake, would you happen to know what size micro switch Kenmore uses? It appears to be 6x6x5mm with 2 pins, but most of what I found with 2 pins are for breadboards, so the pins are flat [0.6mmx0.3mm] not round. Thought if I soldered in a new switch that should fix it.
No sorry I don't. I've never tried to do that before.
