MEBug
- 795.71053.012
- Sears Kenmore
- More than 10 years
My Kenmore fridge isn't cooling down the fresh food compartment and freezer right after 10 years of usage. I followed the technical guidance to check the 3 test modes by pressing the button on the PCB and turned out 3 fans (1 condenser fan and 2 evap fans) are working and there is no blinking LED. In the first test mode, I could feel the light vibration on the compressor by touching it. So I wonder if it is the refrigerant issue. I have not recharge the refrigerant. I found there are white flakes on the bottom tray just under the soldering spots for suction and discharge ports. I also found there are white powder attached on the ports in addition to the copper green corrosion (see first 2 photos). I also checked the IPM output. They are with infinite ohms between each compressor pin and ground. So the compressor insulation is ok. I also checked the ohm between the power pin and common pin and turned out the reading is 10.4 ohm when the room temperature is 63 F (see 3rd photo).
Does anyone know what the white powder on the copper tubes and white flakes are? Are they normal to be seen on the copper tubes? Is the ohm reading 10.4 ohm normal between the power pin and common pin? The technical guidance says it should be between 6 and 8 ohm, but I did use two clamp extensions between the pin and multimeter probe and each clamp extension has 2.3 ohm when itself is measured. The compressor is LG FC75LBNA.
