Kenmore Elite Gas Dryer
buster
How do you remove the lower front panel on the dryer. I suspect that it pops-off but, I'm not sure. There are 2 retaining clips on the bottom of the panel. There are grooves that the panel inserts into. I don't want to damage the panel by trying to pry the thing off.
Hi Buster,
To remove that lower panel on your dryer:
There are 2 clips at the top of that lower panel as well, Take a small screwdriver or a putty knife and then feel around where the clips are, they should be on each side like the lower clips are. Then push in on the clips while pulling the panel forward, and it should release. Some can be stubborn, keep trying.
Hi all,
No model# posted, but maybe like this one?......
There are two clips to be pressed in about 4 inches in from the side at the top of the panel. Press on these clips, pull out on the panel and lift it off a couple clips it mounts on.
buster
Thank you Jake! That certainly helped!
God Bless! Have a Merry Xmas!
Thanks Jeff for that picture.
Glad you got it taken care of Buster.
