billjes
- 110.42924200
- Sears Kenmore
- 1-5 years
I have a three year old Kenmore Elite HE3T washer and I keeping getting the F06 error. My model# is 110.42924200
I read the code book and checked the wiring harness between the Drive motor, MCU and CCU. The diagnostic test works from C01-C08 with no problems. My door lock works fine and my drain pump is clean. It seems I get most of the F06 error code just after Rinse and before the Spin. If I cancel the wash and then hit the Drain/Spin cycle, it sometimes goes through the rest of the wash wihout the F06 error.
I read the few forums that mentioned the F06 error problem and it seems like you need to guess at what parts to replace. MCU, CCU or Motor. I also noticed the Sears Tech's have trouble figuring out what is causing this error.
Beyond the Diagnostic testing, is there any tests I can run with my volt meter to isolate what is causing the F06 error? At arround $150 per part, I hated to install the wrong parts. I did buy the repair manual to make sure I put any new part in correctly.
Any suggestions on what typically goes bad on the HE3t that may be causing the F06 error? If I need to buy several parts to help me troubleshoot, what order should I install them so maybe I can return any unused parts?
THANKS
THANKS
