- 110.44921300
- Sears Kenmore
- 6-10 years
Thought I had fixed my "FH" error code but surprise! It came back. I have now replaced the flow meter & water intake valve and I have cleaned out the trap below and the rinse hoses (which I thought solved the problem before). It appears as though it is draining fine but the "FH" error code came back and the usual cycle of pressing the pause cancel button and then start, had to be gone through to get through that load. I think I have pretty much exhausted the common fixes I have seen here and in other areas of the web- when I run the diagnostic test, the machine stops at C5 and just continues to revolve- it is my understanding that it is supposed to fill with water at that point and that the water intake valve should kick in and allow that to happen. But nothing happens and it is just "stuck" at C5. Any thoughts or advice would be greatly appreciated!
