segk3
- 110.95088401
- Sears Kenmore
- More than 10 years
I only get 3 quick beeps when pressing start. I can select any of the dryer cycles and make changes to temp, time, and sound, but only get 3 quick beeps when pressing start. The first couple of times I unplugged it and tried again I would get a PF error. I had the Machine Control Board serviced and the PF error code went away but I still have the same issue.
Diagnostic code = 49 - all lights turn on/off on the control panel but the dryer doesn't beep when opening/shutting the door. The light does go on/off. Tested the door switch, and replaced it, without any change. Thermal fuse tests ok. Also tried bypassing the thermal fuse by taping the wires together but still have the same problem.
