Kenmore Elite Induction Range 790.95073310 new control panel not working
MultipleMomX5
New York
Our 7 yr old oven stopped working suddenly - one day worked next day did not. Induction stove top works fine. We used a multi meter and found the thermastat and convection element were not working. Bottom and broiler element were fine. We replaced those 2 parts. Oven still not heating. All the wires trace back to the Range Oven Control Board 316650011 and thinking the relay on it is not working. Got that part and replaced - super easy with the plug ins.
We turned on the stove, everything lit up and time showed. However when we pressed any buttons none were responding. We did not get a new overlay - we were going to use a putty knife and reuse the old overlay but wanted to make sure this control panel made the oven work before doing so. Is the Overlay needed in order for the display buttons to work on the control board? If so how can we test it before replacing the overlay?
Is there anything else we could possibly check if the control board is not the issue? Please note we checked the circuit breaker and its fine. We do not see any fried wires either. We plugged the old control board in and all the buttons worked (with overlay on it) but oven still not working obviously. Thank you for any help!!
Range Oven Control Board 316650011​
You got a defective oven control board since the buttons on it do not work and your original oven control buttons do, you see what I mean?
Where did you buy it at? Contact the place where you got it at and tell them its defective and have them send you another new one.
Here's the oven control board for your model:
MultipleMomX5
New York
Hi I got it directly from Sears Parts Direct. Brand new in package. Same model number you listed. Do you think we need the Overlay board in order to make it work and test it though? Thank you I will contact them.
The overlay makes no difference.:)
