Kenmore elite microwave convection combo, half working and awful burt odor.
Melsair
NC
Microwave started a few months ago occasionally failing to heat food, but no indication it wasn't working until the food is removed and cold. Gradually did it more often, then started making a "buzzing/popping sound. Now it will heat for just a couple seconds then starts the noise and an awful odor (unlike the typical burnt motor winding smell). I checked out the capacitor, it's fine. The resistor off the capacitor is rated too high for my meter, so I couldn't check it (what does it do anyway, it's screwed to ground?). I fired it up setting on the shop bench, and the smoke is coming out of the inside of the cabinet. I ordered a new magnetron and installed it, but it does the same thing. Now I'm wondering if I got a bad part. I ordered it off ebay, guy had 100% feed back, exact match, said he'd ordered it for his microwave but changed his mind and didn't install it. What do ya think? Thanks
Still have the old one? If yes, post some pics of it.
Checked the wave guide cover and under the wave guide cover?
Waveguide-Cover-5304464061--00772117.jpg LINK> Waveguide cover
High voltage transformer oK, not burnt?
