FIXED Kenmore Elite Model 110.65962401 - NO HEAT!
Aileen
NJ
I have a Kenmore Elite Electric Dryer Model 110.65962401.
I've only had it for 2 1/2 years!!
Everything seems to be working w/ it, EXCEPT it is not giving off any heat...
Can anyone PLEASE help? My husband wants to go get a part and try to fix it himself to save us the cost of Sears coming out and charging us an arm-and-a-leg.
Thank you!!!!!
This link will guide you to how to take it apart to access your thermal cut-off thermostat on the heater housing and heater itself: http://www.applianceaid.com/whirlpool-dryers.html#four
Unplug your dryer first. Then ohm test your thermal cut-off and high limit thermostat. Take the wires off it first.
Its #47 and #48 on the side of the heating element housing:
(click to enlarge)
Here's the thermal cut-off assembly for your model in case you need to order it:
Manufacturer's Number: 279769
Watch this video to ohm test it, it will ohm the same as your thermal fuse:
[video=youtube_share;3nicyh6EUHc]https://youtu.be/3nicyh6EUHc?hd=1[/video]
Also ohm your heating element for continuity too.
Unplug your dryer first before doing this!
If both the thermal cut-off and hi-limit thermostat ohm test fine, then next ohm test your heating element, its #14 in the parts diagram above.
Your heating element should read between 0-50 ohms.
Here's the heating element for your model:
Heating Element Assembly WP3387747
[video=youtube;wq-3zsiBID8]https://www.youtube.com/watch?v=wq-3zsiBID8&feature=player_embedded[/video]
