Kenmore Elite Model 11060952990 won't heat
lola14
I have replaced the Thermal Cut-Off and the Thermostat on this dryer and the heating element came on for about a minute them went off. I stopped the dryer then restarted it and the heating element won't glow. I took the heating element, along with the Thermisitor and Thermal fuse to the appliance store where all three parts checked out ok.
I thought replacing the Thermostat and Thermal cut off would fix it. If I didn't have 240 volts coming into the dryer the heating element would not have glowed that one time?
I would appreciate any suggestions anyone may have on this model.
Thank you.
imported post
**If I didn't have 240 volts coming into the dryer the heating element would not have glowed that one time?**
Unless one of the 240 volt lines was loose somewhere or burnt.
A copy:
Q - My electric dryer runs but will not heat, what could stop my dryer from heating ?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ... ( your model - even heat board ... relay )
Something here may help.
