- 790.97503000
- Sears Kenmore
- 6-10 years
Need some help with the Kenmore double oven electric. The top oven heats quickly and stays at temperature. The lower oven takes in excess of 20 minutes to reach 350 and once preheated it does not maintain the temperature. Other significant information is that the convection fan runs appropriately and broil element visibly cycles as called for in the preheat phase. Resistance across the bake and broil elements are 16 and 12 ohms respectively. It is reading 270 volts into the unit. What else can I check? Is there a way to verify the operation of the temp sensor? Anything else I can check? Thanks for any help you can give.
Dan
Dan
