Kenmore Elite Washer 110.20932991 - bleach dispenser cup on tub ring not draining/overflowing
shasla
Westchester, NY
We moved into an older home with older appliances and I’m having washer issues. Washer is too loader from 1999 with liquid bleach dispenser cup on front right corner.
Recently I noticed water leaking on the floor after a wash cycle. I removed the bleach dispenser cup and the cup underneath it (part of tub ring) is full of water /not emptying/overflowing with next cycle. The cup you pour the bleach into is filling/emptying fine.
I can feel a rubber hose that takes bleach from tub ring cup to the washer tub. Does this hose have a valve of some type? Seems to go straight into the tub. Hoses/connections are not leaking - it’s definitely the overflowing cup going into washer cabinet and into floor.
Any thoughts appreciated.
Ok,
Here's that bleach dispenser hose:
WP3948705 Bleach Dispenser Hose
You can snake it out with something or use a air compressor to blow the clog out.
You will likely need to remove the cabinet to do that, watch this video below.
