Kenmore fridge 106.57029600 Ice maker is not producing ice
jboletchek
Apex
Ice maker is not producing ice. Water and ice dispensers in the door are working. White plastic fingers in ice maker are pointing up. There is no water in the ice tray. Black water tube is not frozen. Red light on right side does not flash when door is open or when door is open and left side 'door open' flapper is 'closed'. The red light DOES flash repeatedly at an even interval when 'door open' flapper is closed and freezer light switch is pressed off. Any help is appreciated.
Normal would be pointing at you or slightly above you. If yours is not, then it's your ice maker that's bad.
Here's the ice maker for your model, see how the ejector arm fingers should be pointing right at you?
Manufacturer Number 2198597
So your ice maker itself is the culprit.
The ice maker for your model is less expensive here: 2198597 Complete Icemaker Assembly (8 Cube)
