Kenmore Front Load Washer 417.41122410 not working
Nmartin
MA
All cycles, normal,bulky, delicate etc. start to fill with water. Then spin a couple times. After only 3-4min it pumped out the water, the timer goes to 3 minutes and then stops.
The rinse and spin cycle appears to be working OK. Very odd...
Checked motor:
Pins 4-5 have 115 ohms
Pins 1-2,3-2 and 2-3 all have 3.2 ohms. ( Is this to low?)
I have a motor control brd and front control brd on order.
What the heck is going on with this thing :) ?
Any help would be greaty appreciated!
Thanks!!
Stand by while I look for the tech sheet and wiring diagram for that model.
Nmartin
MA
Code E11...not filling in time?
My hot water is off because we never use it...the setting was on cold not tap cold. Changed the setting and all is good. I guess you need water to run this thing. Haha
Thanks for the help!
Correct, the water needs to be on. With all the electronics in it and the price of the machine, it should have told you that!...lol
Here it is Rick.
