imported post
I have a "Kenmore" model 417.29052991 front-load washer that will not drain or spin. It does fill and agitate.
Also, the catch mechanism for the front door makes a buzzing sound at different levels. If I start the cycle while holding the door tightly inward, it is very low. If the door shifts outward, the buzz get louder. Allhinge screws are tight. I thought that this may be tied to the "no spin" problem, but even if I hold the door tight, it still will not drain or spin.
I did see a write up on-line that mentioned pulling the water pump and checking for blockage. It said that the washer won't spin if there was still a significant amount of water in it. Anyone have any input that may help decide if I could tackle this one?
Thanks.
Thanks.
