Kenmore Gas Dryer 110.72702101 drying problems
GSJ
Caledonia, Michigan, United States
It will start up and dry fine for about 20 minutes then it continues to run but the heat stops. Any tips for a starting point in diagnosing it? Thanks
The most common part to go bad on gas dryers when its not heating properly are the gas coils. That is very common when it heats fine at first, then no heat after that.
Here's the gas coils for this model you can order:
279834 Dryer Gas Valve Coil Kit
Ok, sounds good, let us know how it goes.
