Kenmore Gas Oven Wall Unit-F1 Error
NoMoneyNoHoney
Easton, PA
I have an older Kenmore Gas Oven Wall Unit with this F1 error. The model number is 911.3022190. When the oven is not running it keeps beeping and I have to shut the breaker off. The oven does not beep when I'm using it and works fine otherwise. Any solutions. Thanks.
Yes, It would be your clock/oven control board thats bad.
Manufacturer part number WB27T10327 is RepairClinic item number 942797
*Wiring could differ from original, will possibly need to be installed by an appliance repairperson.<INPUT style="WIDTH: 0px; HEIGHT: 0px; VISIBILITY: hidden" id=ctl00_ctl00_cph1_ssc1_pdc_descBt class=normal onclick="javascript:__doPostBack('ctl00$ctl00$cph1$ssc1$pdc $descBt','')" type=button name=ctl00$ctl00$cph1$ssc1$pdc$descBt>
Changing the wiring around can be a nightmare if your never done it before. There are instructions that come with it.
If you don't secede you can return the part within 30 days for a full refund.
Jake<!-- / message --><!-- sig -->
