- 795.78733800
- Sears Kenmore
- 1-5 years
I just moved into a home we just purchased. The icemaker doesn't produce ice. Water does not go into the icemaker. I put water into the icemaker to test if it made ice, it doesn't freeze the water. I checked the temperature in the icemaker and I have seen temperatures from 15 to 60 F.
The fan the blows the cold air from the freezer does run some of the time. The cold water works. I can't get the self test on the icemaker to run. The icemaker is on, the arm is down.
Do I need to order a new icemaker, or something else? I read the other threads on this forum, but the symptoms reported don't match. Even if I need to order a new icemaker, I would like to understand what is not working properly.
Thanks for your help.
