Kenmore micro/hood combo stopped working while cooking - no power
LanaK
Atlanta
I have 4 year old microwave that recently stopped working as I was heating food. It was operating fine and as I walked out of the kitchen it suddenly stopped. The unit shows no sign of power. I checked the outlet first and then the circuit breaker and both were fine. Previously I have replaced the entire control panel with keypad on this unit (about 7 months ago) after getting an SE error code. I'm reasonably handy and have seen online that other microwaves without power usually have a internal fuse to blame. If this is the case, how difficult/dangerous would it be for me to replace these? Also would it require me to unmount the microwave? Any help would be greatly appreciated.
LanaK
Atlanta
I've been out of town and finally got the fuse, however before installing it, I plugged in the microwave and upon closing the door power was restored. It stayed on for several minutes then shut off by itself. I opened the door and realized that tapping on the inside "roof" caused the power to come on so it seems there's a short or bad connection. When I press upwards inside on the top power connects but when I let go it goes blank again. Any idea what this could be as I will need the power off to disassemble the unit.
Maybe.
A short, not likely....a loose connection is very possible.
That sounds like a good idea, slowly keep going until you hopefully find the trouble maker....intermittant issues are the worst!
