Kenmore Microwave 721.80829500 Door Panel
robgcubfan
California
The front door panel cracked on my above stove microwave. I found the part number but It appears the part has been discontinued and no longer available on most sites. It's either Part #383EW1A108A for the door panel or #3581W1A377R for the entire door assembly. I tried eBay but no luck. Does anyone have any ideas where I could look to find something like this that's been discontinued and be certain it's the right color? I did read that it should be done by a professional so they can test that the shielding works. If I do find the part, is that something I should take seriously or is it a relatively easy repair?
