Kenmore microwave oven
magi
imported post
My Mom's microwave developed a crack in the grill above the oven and she didn't want to buy a new grill so i fixed it with some glue. Well about 3 or 4 weeks later she says the grill literally blew off and almost clipped her on the head and landed on the floor. both plastic tabs where it fits into the frame on the bottom are missing from the grill now and both the plastic tabs that the screws hold on are still hanging on the screws on the frame. the grill is still cracked, missing now all these parts and she had to order a new one. She is afraid there is something wrong with the m'wave now and that it will happen again (about a month before that she was about to take out a glass bowl to stir something and the bowl blew up in the m'wave so she is really apprehensive).
Could the m'wave be overheating or something - is there a way to check it's temperature controls? Or do you think it is just coincidental bad luck? The m'wave is about 10 years old-she uses it maybe 3-4 times per week, I'd guess, if that. Anybody ever have this sort of thing happen to them (and no, there was no metal in the m'wave or anything like that-she does store stuff in there like a roll of paper towels and a plastic cover that you put over food when you m'wave it-but she always removes that stuff before use)
Thanks so much for any help anyone can supply!
imported post
magi wrote:
about a month before that she was about to take out a glass bowl to stir something and the bowl blew up in the m'wave so she is really apprehensive.
Super-heating items can happen in a microwave (see the following link) which can under some circumstances lead to explosive results. As with any other cooking appliance, some care must be taken with its use. Check its user manual for operating instructions and suggested cautions. :shock:
LINK > Why does water react in a violent and dangerous way when overheated in a microwave oven?
I have no idea why "the grill literally blew off and almost clipped her on the head and landed on the floor". I can't see it being anything to do with the microwave if whatever grill you're talking about is outside of the oven cavity. Maybe that piece was binding how it was installed and the repair finally gave way under the pressure allowing it to fall/fly off??
JMO
Appliance411.com
=D~~~~~~
zinger
California
Cheap plastic part
It is not unusual to find the grill mounting tabs cracked or broken off completely. I've seen many this way and I believe it's simply bad plastic. The door frames sometimes crack on the outside too.
It is disappointing when the replacement part cracks apart but it does happen.
