Kenmore Microwave
Drew Irvin
I have a 9 year old, over the stove kenmore, Model #721.89941490 that has power, the light works and the time display works, however, it will not heat, or even begin to heat. I was told to change out the fuse. I've taken the vent cover off the top to look for the fuses but can't see any.
Is the fuse the most likely problem?
If so, how do I get to it?
Clarify....you can set timer ok?...timer will start when you hit the button?....timer counts down and ?? happens, fan/lights works, any sounds?
Fuse would prevent everything from working!
Drew Irvin
details
Everything appears to work just like normal, the timer works fine, and it sounds perfect, it makes all the out-side appearances of a working microwave, but nothing ever warms up.
