slumberinn
- 417.24182301
- Frigidaire
- More than 10 years
Hi, this is an old washer and we would like to repair it as a new washer is not within budget right now. Here is what I've done so far to test it. I'm thinking its the motor control board, but would like someone to confirm.
Motor testing. 6-pin plug, ohm readings 3.0 between first 3 set of pins. Pins 5 and 6 read 177 ohms (this is a little out of range) The schematic calls for 184 +/- 7ohms. VAC between 5&6 read 120 volts when washer is running a wash cycle. I'm thinking its not the motor.
Motor control board testing voltage testing during wash cycle
Using pin 5 of the 6-pin plug, I tested the pins of the 10-pin plug. Pin readings are as follows
1- 120 Vac
2- 120 Vac
6- 0 Vac
9- 0 Vac
10- 120 Vac
Can someone confirm if this is likely the board at not the motor based on these readings?
Thanks in advance.
Harry
1- 120 Vac
2- 120 Vac
6- 0 Vac
9- 0 Vac
10- 120 Vac
Thanks in advance.
Harry
