- 790.48083000
- Sears Kenmore
- 6-10 years
My oven will heat up when you turn it on and reaches what temp you set it on. Then will not heat up to keep temp at set temperature. You can turn it off and then back on and it will heat up to set temperature. Is there a thermostat or something that tells it to heat back up that could be burned out or bad?
