Kenmore model 790.92903013 smooth top hot surface lights not coming on
rab474
Murphy,NC
Hello
Today the hot surface indicator lights on 3 of the burners stopping working. Elements heat fine, element light works properly. Looking for direction as to possible causes, diagnosing.Guessing it’s one of the burner switches is bad
Roger
Added complete model number
Hi Roger, I need the rest of your model number. Read it from the tag on the machine. Click here: Appliance Parts follow the link “How to find a model number”
rab474
Murphy,NC
Hello....the full model number is: 790.92903013, brand is Kenmore.
Should also add that the warmer drawer and warmer burner hot surface lights work as they should.
Roger
I located it Rick, I'm attaching it below.
rab474
Murphy,NC
I may be missing something, the PDF file showed the oven not the cooktop.
Are the hot surface lights wired in series, so if one switch or sensor is bad, all the indicator lights will be off?
Thx
No it appears 1B to 2B is the hot surface sensor and each element has one.
