- 795.71099.111
- Sears Kenmore
- More than 10 years
Good afternoon gals and gents,
I have a Kenmore refrigerator/freezer combo unit which is not cooling to any degree at all. When power is supplied, the lights in both compartments illuminate and the control panel on the front door is powered. I adjusted the freezer temp to 1 degree and the refrigerator temp to 35 degrees two days ago but, as of today, neither is cooling to their commanded temps. Both are sitting at room temperature.
I removed the rear panel and, when power is supplied, I found that the compressor is running and the condenser fan is running. The condenser coils were badly gunked up with lint/debri so I cleaned the entire compartment out well and attempted operation again. No joy. The signs I'm seeing here are suggesting that there may be a sealed system issue but I am not seeing any points of leakage and, it seems the unit is a bit new for a clog/restriction.
I'm wondering if there might not be an issue in the temperature control circuit? I removed another back panel to find a circuit board. Not being totally computer savvy, I'm not totally sure how to proceed with diagnosis.
Any info or help anyone here can provide is appreciated.
