FIXED Kenmore model 796.40272900 error IE
JoeyD
Sunnyvale, Ca
Good morning,
We set the washer to run over night, and in the morning there was an error, IE. Has anyone come across this error before? Sunday mornings are the big wash day for us. I am hoping that its going to be an easy repair.
Thanks all,
Joseph
jackofalltrades
NY
It's an error for slow fill. Check and make sure the hot and cold shutoff valves are fully open. If so then replace the hot and cold inlet valves inside the washer.
The links below include videos on replacing them:
HOT:
COLD:
JoeyD
Sunnyvale, Ca
Jackofalltrades.
I was working on an another error regarding my washer, and Jake had asked if I had any luck on the repair that you suggested in this link. After reading your message, I went in to look at the supply valves- the hot water supply didn't look to be fully open. I also went in to the back side of the machine- using the video links you sent above (thanks) and checked connections. everything seemed fine. I put the machine back together, and I intermittently have the error- really meaning- just once or twice. The error isn't coming back all the time like it was before I opened the supply pressures to 100% open.
Thanks for looking into this, and sorry for not responding initially.
Joey.
