Kenmore Over the stove Microwave
tebb23
US
Hello all,
Last night my 20 year old microwave just stopped. I did some research today and found it had an inline fuse which I replaced and temporarily fixed the problem. However, once I turned the microwave on, just was testing it on a cup of water, it almost immediately blew the fuse again. This is happened both times while the microwave was running. Honestly if it didn't seem like such a bear to replace I would just go buy a new microwave, but it doesn't seem to be a slide it out, slide in a new one situation. Anyway, I am hoping someone can suggest a fix/solution to this issue, I am no expert, but have had pretty good success fixing many of the appliances around the house with the proper guidance. I have googled and youtubed this issue and searching the way I have, have come up empty.
Thank you in advance if anyone has an idea on what the heck could be blowing the fuses. :confused:
Depends on when the fuse blows...
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
tebb23
US
Good morning Jeff and thank you.
Both times, last night and this morning, it happened while the microwave was running.
tebb23
US
If the microwave has been off for several hours, does the capacitor lose it's charge? I am thinking I can replace it, I just want to be sure I don't get zapped, it has been off quite a while. The capacitor sits right up front and I can handle it fairly easily and just make notes on how everything reconnects.
No...it can, but no.
As soon as you hit the start?...that is often a shorted capacitor.
Discharging a cap..
Ohm meter testing a capacitor...
Capacitor Testing | Appliance Aid
Once discharged, they are easy to replace and handle.
tebb23
US
No, not as soon as I hit the start button. The first time was about 7-10 minutes into heating something. The second time, after I had replaced the fuse, I only set it for 10 seconds and it popped the fuse 5 seconds in. So neither was a bang bang thing, both times the microwave came on, ran a bit then blew the fuse. I pulled the cap and am going to try that first, other similar issues I have read were fixed by replacing the cap.
Should I go ahead and replace that diode also? Or would that be a completely different set of malfunctions?
Thank you again Jeff for your time and patience in answering my questions.
Only if it tests as bad. Most times a bad diode doesn't blow the fuse, makes a load buzzzz noise and no cooking.
