FIXED Kenmore Pro 790.42003600. Upper oven does not hold temperature all the time. Some times it does some times it doesn't.
Peter Dahlquist
Kenmore Pro 790.42003600 Upper oven will not hold temperature. Example start at 350 deg and it will drop to 300 deg or less. I have changed the mode control switch, the temperature sensor and the temperature control switch.
Hi Peter, Another member had this same problem, and it was the relay board that fixed it:
Your model uses the same exact relay board as his:
Ok Peter, sounds good, keep us posted.
Peter Dahlquist
OK I swapped out the relay board ($234 I think). The old board had a resistor that bit the dust and left a scorch mark. Calibrated the oven. Seems to work.
Temp does drop but pops back up quickly. I realize how the oven works, heating element is on until temp is reached then turns off. Cycle continues till cooking complete. It will start at 350 degrees drop to about 300 deg pops back to 350 deg. Have a new heat sensor, new temp control switch and mode select switch also.
So I'm assuming it works.
Excellent Peter, glad to hear the new relay board fixed it.(y)
