Kenmore Range 790.75233313 gas oven and broiler not turning on
David 790-75233
New York
The gas oven and broiler will not turn on. It looks like the igniters are glowing. Help, please.
Kenmore 790 models are made by Frigidaire.
Ok, Lets first check the little lever on your gas regulator to make sure that's not closed. If that brass lever is down, then its fine and the gas is on to the oven. It should be vertical(ON) not horizontal(OFF)
Here's the photo of your gas regulator, see the brass lever on the back right side of it?
David 790-75233
New York
The valve is on. The oven works intermittently. Today it did not work when I turned on the oven, but a few minutes later, I turned it to convection bake and it went on.
If both are glowing orange but NOT opening up the oven gas safety valve every time, then measure the amperage draw of the ignitors. It needs to be 3.2 - 3.6 amps for the oven gas valve to open properly and every time.
Here's the BAKE igniter glow bar for your model:
5304506545 Oven Igniter
