Kenmore Range 790.90133704 Oven SAb Deactivation
USA
Hello, I have a Kenmore oven and electric range model number 790.90133704 that is stuck in SAb mode. I have tried many online button sequence recommendations with little success.
Does anyone know the proper buttons to push to deactivate Sabbath mode on this model?
Which was what exactly? It's difficult to suggest anything when we don't know what's been tried already.
Your range was made by Frigidaire/Electrolux. Instructions for one of their range models would likely be similar. Here are some possibilities:
One is pressing and holding the bake time and clock set keys simultaneously for at least three seconds will set or end that feature.
or
Press both the "cook time" button and the "delay start" button at the same time for at least 3 seconds.
or
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
There should also be a 'tech sheet' inside the range with its wiring diagram. The tech sheet will usually contain such information specifically for that model.
