Kenmore Range 911.64278790 Oven light sparked, nothing working
G
Guest
Guest
Trying to replace the light but can't find the part for this model. While trying to see and compare parts in light assembly the wires possibly touched and sparked then everything...clock, burners and oven stopped working. I flipped the breaker off and on again but nothing happened. The flashing clock and surface light came on when I tried the burner but it didn't heat up. Any suggestions would be helpful. Thanks
Yes, you are always suppose to disconnect power to the appliance before working on, seems there have been a number of people not doing that lately, your not the only one.:)
All electrical ranges have dual breakers, go back to your breaker box and turn BOTH completely OFF, then ON again and that should fix it. But put that light socket assembly back in place FIRST.:)
Are you looking for the complete oven light socket assembly or just the light bulb?
Here's the oven light bulb socket assembly for your model:
WB08T10002 Oven Lamp Holder
