Kenmore Range Error Message
toolman5125
imported post
after running self clean cycle,door never unlocked...and the above error code appears? :? ?
imported post
**E-1,and F-5**
Some of the codes in the clock where programed backwards....some may show E-1,and F-5 and some may show F5 - E1.
A copy:
[align=left]F5 - E0 F5 - E1 and E2 [/align]
[align=left]Check door/latch switch [/align]
[align=left]Replace switch if defective [/align]
[align=left]Replace component[/align]
Since this happened after a clean cycle, something may have happened to the door lock or door lock switch:( They would have to be checked.
toolman5125
imported post
thanks,,after finding cam switch in back,i simply rotated it and powered back up..all is well...thanks again.... Tim:)
imported post
Glad to hear you found something! :)
If it occurs again the switch ( assembly probably) may need changing.
dodsonr3@aol.com
imported post
toolman5125 wrote:
after finding cam switch in back, i simply rotated it and powered back up..all is well.
I have this same error message, where is the cam switch located at?
imported post
toolman5125 mentioned **after finding cam switch in back**
Seems thier's was at the back of the range.
