Kenmore Range Model 790.9641940C clicking and popping when bake button is pushed
MrBibs
Missouri
790.9641940C
When I push the bake button and hit the up arrow once it shows 350 and as it tries to engage the oven it starts clicking popping and smoke comes off the main board. I have replaced the main board and both relay boards and it still does this. I've checked the continuity of the thermostat and the baking element and both seem to be ok. Any ideas? All help is greatly appreciated.
The lower relay board -appear- to be for the surface elements only.
The clock/control is for the oven....and you installed a new one of these?
Electronic oven control
*Sounds* like a bad control to me.
Both elements and oven temp sensor checked ok? Wiring and wire connectors have been checked?
MrBibs
Missouri
Yes they both checked ok and yes i replaced the control board but not new was used off ebay.
Sounds like you got a bad one then :(
I think that would be best....JMO!
