Paul2021
- 106.50023211
- Sears Kenmore
- 6-10 years
I have a Kenmore Coldspot refrigerator (manufactured in 2013) that I'm having an issue with that is somewhat different from the ones I've seen posted regarding frost buildup in the icemaker. Frost is accumulating at the outlet of the ice bin (photo attached). The chute through the door is ice-free, and the flap closes properly, so it doesn't seem to be due to air leaking around the flap. The door seal has no noticeable tears or worn spots, so room air leaking around the door doesn't seem to be the source, either. This is in a rental property and has been an issue only with the current tenant, though it may be that previous tenants just didn't tell me about the issue or use the icemaker. (Actually, when a previous tenant moved out, the ice bin had a hole in it and I bought a new one, so that tenant did have an issue with it.) When thawed out, the icemaker works properly for a couple of weeks until the frost builds up again. Any suggestions for what else to check would be appreciated.
