Kenmore Refrigerator 106.51335710 Ice maker not filling with water, Diagnostic mode
Durango099
Newport, Oregon
My Kenmore all of the sudden it doesn't want to make ice.
The ice tray is empty, and doesn't appear to be filling.
So in reading the guide, it says I need to run diagnostic step 45 - HOW???
I can't seem to locate anything that explains how to put the system in diagnostic mode
Thank you in advance
What guide? Do you have the tech sheet for that machine? If not, look behind the lower grill or taped to the bottom of the machine on the right side behind the grill. I don't think you have the option for running test 45.
Manually fill the ice maker tray with water. Give it a few hours and see if it dumps the ice.
LOL, Rick he posted this in 2 threads.:)
Here's the guide I posted in post #2 here:
I then uploaded his tech. data sheet in post #4 so he can run STEP 30.
@Durango099 lets use this thread that you started to keep posting in, posting in 2 different threads is too confusing.
Thanks Jake. That's the one I was looking for!
Isn't there a $25 fine for posting the same question in more than one thread??
Not as of yet, only to folks who go wild and crazy and post the same 7 or more times like that guy did last month, then its $25 X 7 plus tax. LOL
Was that the person complaining about Whirlpool refrigerators? I deleted them all and told him I'll leave his original post if they promise to quit complaining in every WP thread..lol
Durango099
Newport, Oregon
Sorry for posting it in a reply to the user post I found, and for making a new post hoping to gather input from others that may not have monitored a post of January.
Armed with the tech sheet Jake provided, I was able to run the tests as well as a manual water fill with a straw. After a couple hours, the manually added water caused the tray to eject frozen cubes, but nothing since.
The water fill procedure seems to be the failing item; during the test #31 the display shows water fill, then fill stop, but I do not hear water flowing.
A new filter has been installed, and the exterior door water works well. 10 second fill test on the door water, produces 1.25 cups of water.
Sounds like the ice maker is working correctly but the water valve is not working. Here's the part you need:
If you want to do a quick test to confirm the water valve is bad, Remove the mounting screws holding the water valve to the machine so you can maneuver it. Disconnect the water line under the brown coil and disconnect the two wire connector on the brown coil. Position the valve over a container to catch water and use a cheater/test cord to supply the brown coil with 120 VAC. No water, bad valve.
You nailed it Rick! LOL
Sounds good Keep us posted. You know I was just kidding you about the double post, right? It happens all the time. LOL
Durango099
Newport, Oregon
After replacing the water inlet valve, still no water in the ice tray :mad:
I can hear it trying to fill, but nothing happens. Next up in the replacement chain?
Give it 24 hours and check again. After replacing the water valve there's going to air in the lines. If you run a few gallons through the dispenser, that will get most of it out. There's still air in the ice maker line. It sometimes takes 2-3 harvest cycles before water reaches the ice maker.
No need to use a straw and fill it. It will go through a harvest cycle on it's own as long as it's turned on.
Durango099
Newport, Oregon
I just returned from a week long trip to Alaska and still no ice :(
10 second water pour at the door remains 1.25 cups of water - so the supply seems good.
Did you check the fill tube that fills the ice maker with water, to make sure it wasn't clogged with a ice blockage? Blow through the plastic fill tube line and see if there is a blockage in it.
There should be a quick disconnect behind the bottom kickplate grille to disconnect that plastic fill tube line, then blow through it.
