Kenmore refrigerator 596.76593600 not shutting off.
flashover06
NE Ohio
Hello...new user and thanks in advance for any help.
Unit is about 11 years old. I replaced ice/water valve last summer. Over the last few days, the fridge won't stop running. We noticed it when we found a few items were partially frozen, then the water dispenser started dispensing slush. I put a thermometer in there and it was reading 30 degrees. I adjusted the temp up to about 45 and waited. It did shut off and temp went to about 36. Then it went back down. I tried (twice) shutting off the breaker for a few minutes in an attempt to reset (this worked in the past as this problem has happened a few times over the life of the unit). Didn't work this time. The coils are clean (I do this twice a year). Today, tried breaker again. The built in temp gauge showed freezer at -3 (set at 0) and fridge at 43 (set at 45) and my stand alone gauge showed 28. Anything else I can check?
Its most likely the refrigerator section thermistor or control board. Check the thermistor first by removing it and warming it in your hand to room temperature then use a multimeter to ohm test its resistance. At room temperature (77*F) the thermistor should measure about 10K ohms.
Here's the thermistor for your model:
12002355 Thermistor Kit
When you click the link to your thermistor you will see a video on how to access it in the refrigerator section.
