- 970R724381
- Sears Kenmore
- 6-10 years
Noticed a couple days ago that the ice maker on my fridge was no longer dumping ice. At that point there was a full tray of ice waiting to be dumped, but it was just sitting in the tray. I took it apart today and removed the icemaker assembly to check for anything frozen, visibly broken, etc. I saw that the ice level arm (the white plastic one) appeared to be in an "up" position, I opened up the gearbox on the end of the assembly to check for anything stripped/seized and I reset the arm into the "down" position. Dumped the ice that was in the tray, reassembled everything and powered back up, now I'm seeing that the tray isn't even filling. Before I go and order a replacement icemaker assembly, was wondering if there was anything else I can/should try? Water pressure seems fine, water's being dispensed at the door same as it's ever been. I also replaced the filter to see if that makes a difference but didn't seem to.
