kenmore series 70 gas
misterroboto
imported post
model# 110.78702894
$100 at garage sale
no heat- had to replace gas valve solenoids
one month later no heat- thermal fuse is dead-
do i need to worry thatmy operating thermostat is welded closed- thus allowing it to get too hot back there? after replacing the th. fuse, is there a way to check forthis before sewing the patient back up?
thx
aaastan
Wilmington, Delaware, USA
imported post
I assume that you've tested the operating thermostat with an ohmmeterwhile it was cold and it was a"good" reading. That would not necessarily mean that the thermostat is "welded" or "stuck".
If that's the case--I would start checking the entire exhaust vent from the rear of the
dryer to the outside vent hood--looking for blockage. You can also run the dryer
without the vent hooked up at the rear and feel the air coming out of the dryer vent-it
should be a steady and strong flow of air. If not, there will be blockage inside the
blower housing itself(where the lint filter slides into). That would require a tear-down of sorts to gain access to the blower housing.
John
