- 110.20702990
- Sears Kenmore
- More than 10 years
My top loading washer (direct drive) stopped in mid-cycle on Sunday after washing/agitating. My wife came into the laundry room to find it "humming". Tub was full of water. I came home and played around with it, and found:
1. The hum occurred on all cycles when it got to the point of draining, but agitation is fine on all cycles. (Did this after jumping the lid switch harness - the lid switch is not the problem.)
2. The motor capacitor seemed to check out OK with an ohm-meter (but I can't confirm the microfarad reading)
3. I pulled the motor: The coupling and water pump are fine. The coupling connected to the transmission spins easily. Pump is not clogged. It is not a mechanical problem in my opinion.
4. I wired up the motor while it was off of the machine, and the hum still occurred when the timer gets to the point where it should drain; this happens on all cycles. One time, while it was humming, I twisted the shaft and got it start up.
5. Thinking I needed a new motor, I bought one ($180+), installed it, and the problem still occurred!! It won't drain (or spin).
6. A new capacitor should arrive today, and I'll install it in a few seconds...
If the capacitor doesn't do the trick, what could the problem be??
