Kenmore Ultra Wash 3 not cycling or draining
newhallsr
Richmond, VA
I have a Kenmore Ultra Wash 3 (6651674992) that we bought used and have been using without any problems for about 4 years. However, last night it stayed in the wash cycle the entire night and was still in it when I got up in the morning. I turned it off and it there was water up to the overfill float that would not drain. I figured that it had something to do with whatever controls the cycling as it should not stay in the wash cycle that long but I'm confused about why the water wasn't draining. I checked the drain tubes and check valve and there were no clogs. What do should I check? Is this all stemming from one problem or is their something wrong with with drainage system and the system that controls the cycling?
Yes, that timer jack linked to should fix it.
