- 253.29111990
- Sears Kenmore
- More than 10 years
I have a Kenmore upright freezer model number 253.29111990
I guess it is 15 plus years old, it was in the house when I moved in. It has worked great since I have had it.
Recently I discovered the door seal was leaking air (excessive frost inside starting to turn to ice)
The door seal was leaking at the upper right and lower left corners.
I replaced the seal and now the door doesn't seal on the left (handle) side at all. The top, bottom and right(hinge) sides seal though. Is there any way to correct this?? (The inner panel is not cracked or broken anywhere and all of the screws are present)
