Kenmore Wall Microwave 911.49485992 strange buzz sound with smell that smells "electronic"
mrhouse
Northeast
Older wall microwave. (20~ years)
When running strange buzz with smell that smells "electronic"
Stopped it immediately when I heard the buzz. Doesn't sound like
a normal microwave buzz.
Sounds slightly higher pitch.
Will appreciate ideas
Could be the HV diode. Check it with a meter. It should be open in one direction and closed when you reverse the test leads. Did it stop working/heating?
