joshuagodinez
- 110.22102311
- Sears Kenmore
- 6-10 years
Problem happened on and off, but then started happening all the time. Error code F7E1. Multimeter test on control board connectors was good. Brake sometimes was engaged without being able to disengage making manual tachometer test unavailable, but unplugging the washing machine for a few minutes would disengage the brake upon plugging the machine back on (or maybe it was something else). Now, that doesn't work. Seemed electrical (no signal to tell brake to disengage) and with the connectors testing well I replaced the main control board, but that didn't fix the problem. First step in tech manual is "if basket does not turn freely, determine what is causing the mechanism friction or lockup". How?
Thought it might be clothes under the agitator that's got it binding up, but took it out and nothing there. Tried to remove the inner basket to check for clothes under that, but it's frozen on the axle which seems to be a common problem. So, I wanted to check the shifter directly and took it out, but without knowing if the brake is engaged by the shifter seems like a waste of time (but I'll test all the pins and then curse my waste of time). Since the tachometer is in the shifter it seems like it makes sense that the shifter would be involved. Online says how to replace brake and what a brake does (stop the spin, duh), but not what controls the engagement/disengagement of the brake.
Basket not spinning freely by hand seems like it can be multiple things: clothes under the agitator, clothes between inner and outer basket, brakes engaged which can be alleviated by lubrication, shifter(?), bad brakes which need replacement, brake cam, brake assembly, brake bearing. Is there really no way to know which of these things is the issue without disassembling the whole washer?
On other posts I notice recommendations to replace the brake/clutch assembly, but I'd rather avoid if there's something simpler to try since I'll have to take things apart that I don't know if they're necessary to take apart. So, how can I force a brake disengage to see if the brake is the issue?
