AlanP64
- 110.26002011
- Sears Kenmore
- 6-10 years
So, as the title states, it will not drain and spin. It will not advance from wash mode to rinse then drain and spin. I have tried to just run it in drain and spin mode as well and no dice. I messed around with it for about 30 minutes trying to get it to work. At one point I was finally able to get it to perform a complete cycle including drain and spin. It actually did two loads. Third load, back to the issue.
I found a similar thread on here but wasn't sure if I should tag along on that one or post a new one. I ran the diagnostics and found two codes. One is F9 E1 which if I am not mistaken is "Long drain time" which makes sense seeing that the tube will not drain and start a spin cycle. The other code is an F5 E1 which I found was a lid lock error. This washer for a long time has been real glitchy on the lid lock. It will sometimes lock then unlock a few times at the start of the wash cycle.
Sometimes you have to hold down on the lid where the lock is located in order to get it to lock. I'm not an appliance guy but I tend to think that code is likely unrelated to my present issue. After that, I tried to run the different diagnostic tests.
The agitator will work in gentle and heavy. Drain and spin test wouldn't do anything. I pulled the drain hose out of the wall drain and was able to empty the tub. Then I tried high and low spin. Would not do anything. Wouldn't even try to lock the door.
A bit more information. I am deaf but all the while trying to get it to drain and spin I could feel a vibration as something was trying to run or running. I recorded a video of this and sent it to a friend. He stated, "All I can hear is a shaking or rattling sound. Sounds like a rotating rattling." That worried me about the drive motor possibly, but if that were the case, how would it agitate at all? I am wondering if the shaking and rattling is the pump since the error I am getting is related to long drain time. Sorry for being long winded, I just wanted to provide as much information as I could
