yuckypants
- 110.26002012
- Sears Kenmore
- 6-10 years
Hello all -
I had this problem about 6 years ago and while the symptoms started the same.
I don't believe it's the same issue:
www.applianceblog.com
I found during testing that the basket will not free spin under any circumstances. I can freely spin the agitator as well as conducting a manual diagnostic HEAVY AGITATION; however, when I attempt HIGH SPIN (or LOW SPIN) it fails. I actually can't remember if the basket is supposed to free spin, but I believe it is, especially when the unit is unplugged.
I tried to pull the unit apart from underneath, but cannot get very far - removing the pulley assy seems nearly impossible. I can't get the center bolt off of the pulley since the agitator freely spins. Also, as I'm writing this, I may have had an epiphany - if I remove the shifter, I can put the pulley in a locked mode - and then I can remove? Either way, I don't think I'm going any further until I talk to someone on here to see if I'm on the right path.
I'm retesting to get error codes after messing with it, but I had an F7E1 when I initially looked over the codes.
Looking forward to your expert advice.
FIXED - Kenmore 110.26002012 with an F7E1 code
Hello all - I found a thread that seems to be my basic issue (https://www.applianceblog.com/mainforums/threads/53886-F7E1-Code-Washer-stops-before-drain-spin); however, it's a little old and I'm a little confused about some of the troubleshooting steps. For starters, I'm experiencing the...
