Kenmore washer 110.29432800 not spinning
Niceseol
MO
Hi!
My washer isn’t spinning. I still can hear it’s running but just not turning. I checked the bottom of the washer. The coupler seems intact - not broken or worn. The clutch has resistance and it rotates when the washer is in spin mode. Basically the metal bar of transmission does not spin while the clutch is spinning. I have a video of it and it’s attached.
Please also check the attached picture. Is this a transmission issue or some type of spring, drive block or locking mechanism issue? Thank you.
  • IMG_6605.MOV
    3.6 MB
Seems like its either the clutch or basket drive. Your Kenmore 110 is made by Whirlpool, so it uses the exact same parts.
Here's another person that had a similar problem:
Clutch Assembly 285785
W10820043 Basktdrive
