Kenmore Washer is Leaking Model 110.24692300
Klabiuk
Winnipeg
I have a Sears Kenmore, Special Edition, top loading, washing machine. Not exactly sure of the age. We've noticed lately that the washer is leaking from the bottom back of the washing machine. Help! I've read a few threads about leaky Kenmore where @theripster mentions replacing the neutral pak. Could it be the direct drive water pump? Would that leak at the back? Could there be any other ideas? Where do you buy this neutral pak from?
We took apart the back panel to the washing machine to see better but having a hard time figuring out how to remove the back side.
I really don't want to have to get another washing machine as you can't control the water level like you can with these older ones.
Klabiuk
Winnipeg
We were able to remove the metal casing from the control & back panel. The leak doesn't seem to be coming from the drive water pump as that is all the way at the front of the machine. This is just coming from the back end of the machine (and not from the outside). It's not a lot of water but would like to fix it. The plastic drum had a little bit of water on it but that could just be from jostling the machine a bit to remove the metal casing.
Rick posted the neutral pak in post #4 here:
You can't remove the back panel, you have to take the cabinet off to access the inside parts:
You will need to try to pinpoint exactly where that leak is coming from, get a flashlight or floodlight to see better underneath the washer.:)
